Brief Description: Rivet on HS interferring with Elevator movement
There is a rivet on the HS whose shop head rubs against the leading edge of the left elevator. This rivet needs to be drilled out and replaced with a flush rivet going the other way. This will remove an interference.
The rivet on the HS to the left of the bolt head rubs against the elevator leading edge
This is the position of the elevator at which the rivet rubs against the elevator
