Brief Description: Enlarged Control Stick Openings/Rudder Cable Strap
Enlarged both of the control stick openings in the floor panels for the elevator movement fore and aft by about 1/8". Positioned the floor panels in place. Placed one set of seat cushions in place. Tied each rudder cable to the rudder pedals with ties and set the distance at about 2 1/4" between the pedals and cables. I sat in the cockpit to see how the pedal distance felt. The 2 1/4" is about right. I cut two strips of the steel strap at 2 3/4" length and rounded off the ends using the Scotchbrite wheel.
