Brief Description: Started Working on Replacement Floor Panels
Measured and cut off 3/8" of the aft end of each seat pan, as well as the corners of each pan on the bandsaw. I then checked the fit and trimmed the corners of each pan to try to get a close fit. This was done using the Scotchbrite wheel and files.
Visitors-Jeff, Tim, and Rick(Tim and Rick are VK-30 builders)
