Brief Description: Continued Working on the Left Floor Panel
Kept working on the F-639 seat panel drilling the remaining screw holes in the seat panel. A few holes did not line up so I used the circular file to enlarge the holes to match the position of the existing holes. Used the Dremel and cutoff wheel to make the holes for the control stick and the crotch strap. The crotch strap hole was filed to the proper size. The control stick hole needs to be enlarged.
Left floor panel almost completed
New nutplates installed properly on the three left ribs
