Brief Description: Finished Working on the New Left Floor Panel
Used the pneumatic squeezer to dimple and then rivet three MS21019 nutplates to the flanges of the three ribs on the left side. I positioned the left floor panel, F-640, in place with screws. I had to file open a few screw holes and then got the entire panel to fit properly. I cut out a small hole for the control stick with the Dremel and cutoff wheel and cleaned up the edges. I trimmed the right floor panel, F-639, on the right side to make it fit better.
Floor panels in place
Left panel complete except for the center rib's screw holes
