Brief Description: Started work on the Aileron Trim Bracket
Used the drill press to drill #10 holes in the aileron trim pivot block, Also drilled a 3/16'' hole in the side for the notch and filed the hole open for the notch. I used the Scotchbrite wheel to chamfer a radius on the one side.
