Brief Description: Made F-612B Spacer/Drilled in place
Received my order from Wick's. Measured and cut out the F-612B spacer out of the angle. Starting with pilot holes, I drilled the bolt holes in the spacer and the longerons. Readied the aft top deck for riveting it back in place. Took nuts off the bolts on the aft end of the fuselage. Drilled the holes in the HS rear spar/VS bracket up to 3/16" size.
