Brief Description: Finished Drilling HS/VS Spars-3rd VS Bolt Hole
Finished drilling the front spar brace F-681 to the forward spar of the VS and the bottom bracket of the HS forward spar. Drilled all holes up to #30. Took VS off the fuselage and deburred all holes. I used a laser to mark the top right hole for the tailwheel bracket, clamped the VS in place, and drilled a pilot hole. After much measuring, I drilled a #40 hole to start and drilled it up to 7/32''. I then used the 1/4'' drill to finish the hole.
