Bolted the pitch servo to the bracket. Practiced safetying the pitch servo to the bracket. Got good results, so I cut the wire off and did it again. This ended with good results, so I left the servo in place. Used rivet gun to rivet pitch servo bracket to F-629. Used AN426-4-5 and AN426-4-6 rivets. Countersunk fuselage skin for the two rivets, Attached the control rod between the pitch servo and bellcrank. Drilled out the temporary pop-rivets holding the right F-621B canopy deck in place. Cut and trimmed the aft end of the right F-621B using the left camopy deck as a guide.
