Brief Description: Cleaned Fuselage/Drilled Fuselage for Conduit
Using lacquer thinner, wiped off underside of fuselage at location of all antennas and strobe power supply brackets. Measured down 1'' from longeron and drilled 1/4'' holes in F-605 and XX for static line. Used Unibit to drill 1/2'' holes in Xx and Xx between baggage and aft seat ribs for split plastic conduit. Conduit will be used to run wire from aft baggage area forward. Installed control rod between control column and elevator bellcrank. Found that the weldment on the control column interferes with the full movement of the control rod. Started to file part of the weldment away.
