Brief Description: MB Bracket Drilled into Fuselage
Used bandsaw to cut out doubler plate for the marker beacon antenna. Cleaned up edges using the Scotchbrite wheel. Used the bending brake to put flanges on the MB doubler plate. Drilled pilot holes in marker beacon antenna bracket. Drilled bracket to skin in left bay aft of the baggage bulkhead. Drilled the bracket to the skin with #40 bit. These holes will be dimpled. Drilled the holes for the BNC connector up to 1/2'' with the Unibit and the other two holes to 5/32'' and 7/32''. Cut angles off antenna bracket flanges and smoothed edges.
