Brief Description: Installed Nutplates on EF-601 Channel
Clecoed flap side covers to EF-601 and drilled holes from #30 to #19. Deburred all holes and drilled #40 holes for nutplates using nutplate jig. Drilled an access hole in the left F-605 cover for the AN4 bolthead. Used pneumatic squeezer to rivet nutplates to EF-601 channel. Installed flap motor in the channel.
Measured and drilled pilot holes in the F-605 bulkheads for the AN3 bolts attaching the flap bearing blocks. These holes were then drilled up to size.
Left Flap Side Cover Fitted to EF-601 Channel
Hole cut out of Flap Side Cover for Flap Motor Bolt
