Brief Description: Trimmed Flap Side Covers/Static Line
Trimmed forward ends of both F-605 flap side covers to approximate cutouts for the bend in the floor. Drilled pilot holes in flap cover EF-601. Clamped flap side covers to EF-601 and drilled holes up to #30 with angle drill. Deburred all holes.
Drilled hole for static port T-connector screw in bulkhead F-610. Also placed a backing spacer behind the bulkhead for the screw. Placed three mounting bases on same bulkhead for zip ties. These will hold the static tubing in place, but I will replace them with lacing cord.
Visitors-Emmett Starks, Steve Jankovich, Doug Robison
