Brief Description: Drilled Left Crotch Strap Brackets in Place
Positioned and drilled left forward crotch strap bracket in place. Placed floor panel in place and drilled pilot holes in floor for attaching floor to crotch strap brackets and modified bracket on forward side of rib. Had to file one hole closer toward center of bracket because I had not correctly measured the position. Did this to both the bracet and the floor panel. Drilled these holes up to #19 size. Drilled nutplate holes in forward rib bracket and dimpled them.
