Brief Description: Control Sticks Drilled/Static Ports/Seat Rib
Drilled out second rivet and then dimpled and riveted nutplate to removable seat rib. Used die grinder to smooth edges of modified ribs. Measured and marked both sides of fuselage for position of static ports. Drilled #30 holes in each control stick for wires to exit from. These wires will come from the push-to-talk button on the right stick and the five buttons on the left stick. These holes will need to be enlarged, especially the left stick.
