Brief Description: Trimmed Control Stick Openings/Removed Seat Rib
Used cutting bit on Dremel tool to trim openings in seat ribs for control stick movement. Took control rod and removable part of seat rib out. Had to drill out one rivet on a nutplate for the left floor over the main spar. Need to drill out other rivet and then dimple and rivet nutplate to rib only.
Control Rod and Seat Rib Removed
Lightening Holes in Seat Ribs Opened up for Control Rod Movement
