Brief Description: Drilled Back Stop Brackets in Place/Primed Parts
Clecoed shims in position on left side and placed scrap .020 pieces on aft edge of shim to provide that 1/8'' clearance. Clamped angle bracket to F-605E on right side and drilled bracket to F-605E with #30 bit. Deburred all holes. Scuffed, cleaned and primed remaining pieces of seat components. Attempted to rivet a hinge to a seat back brace with pneumatic squeezer. The squeezer jammed and locked on the rivet. Had to screw out the bolts in order to get the squeezer to release.
