Brief Description: Finished Trimming F-642 Left Floor
Continued to trim F-642 left seat floor skin along fuselage side. Drilled pilot holes for seat belt brackets and then used cut-off wheel to trim areas. Used files, Scotchbrite pads on die grinder, and Dremel tool with a sanding tip to round corners and smooth edges. Finished holes for seat belt brackets. Clecoed F-647L left baggage floor skin in place. Clamped F-642 left seat floor skin in place.
Used Dremel Cutoff Wheel to Make Seat Belt Bracket Hole
