Brief Description: Swapped Roll Servo for Pitch Servo
Received email from Zach-TruTrak after he looked at my pictures of the pitch servo installation. He said that I had installed the roll servo instead of the pitch servo. He thought that, with the switch, I should be able to move the control rod to the right of the bellcrank. I found that I did have the roll servo installed instead of the pitch servo and swapped them out. Found that the alignment is still better with the control rod on the left side of the bellcrank. Took baggage bulkhead panels off. Deburred all holes.
