Brief Description: Route Rudder Cable/Cut Hole in Left Side of Fusela
Finished running rudder cables thru all holes along fuselage and installed all snap-in bushings. Had to pull out and reroute right cable and bushings to F-608 bulkhead because cable was routed thru wrong hole. Measured and drilled pilot holes for left rudder cable exit. Enlarged holes with Unibit and then Dremel tool. Used Scotchbrite wheel in die grinder to clean up edges, inside and out. Drilled #8 hole in scrap stock and countersunk the hole. Placed the stock piece behind the holes drilled in the fuselage and used a screw, washers and a nut to dimple each screw hole in the fuselage for the rudder cable clamps.
Shipped camloc kit back to Jeremy-MilSpec for free replacement.
