Brief Description: Drilled Pedal Bearing Blocks/Positioned Rudder Tor
Ordered tools from Cleaveland Tools.
Drilled pilot holes in rudder pedal bearing blocks, F-6116. Positioned torque bars in fuselage to check fit and orientation of 6116 brackets. Used 3/16'' reamer to clean out holes in torque bars. Connected the left side rudder pedals to the rudder pedal assemblies. Used long bolts, AN3-56, to connect pedals to rudder pedal assemblies. Inserted washers as needed. Attached brake cylinders to rudder pedal assemblies.
