Brief Description: Corrected Rivets on Rudder Pedals/Bolted Pedals to
Drilled out rivets on other two pedals. Countersunk holes in pedals and on side plates, F-6117A. Reriveted brackets to the two pedals. Riveted side plates to side angles.
Bolted two pedals to rudder pedal assembly. Used long bolts, AN3-56, instead of the short AN3 bolts called for in the plans, because of problems noted by other builders. These problems include not having the pedal aligned properly and then it does not operate properly in using the brake.
