Brief Description: Drilled Shoulder Harness Anchors/Worked on Fuselag
3.0 11/30/07-Reviewed Van's plans/instructions and compared them to the quickbuild fuselage. Used Scotchbrite wheel to clean up edges of shoulder harness anchors, F-636. Drilled anchors to top longerons, left and right, for bolt holes. Deburred all holes. Used Scotchbrite wheel to clean up edges of bulkhead F-609, Drilled pilot holes in flange of F-614 for positioning F-609 bulkhead. Deburred all holes.
To Do: Found that left side of fuselage near bulkhead F-609 had one hole not drilled in skin. The hole was drilled thru longeron. Need to drill hole thru skin, dimple it and rivet.--Done 12/4/07
