Brief Description: Right wing access panel and wingtip work.
I finished fabricating and installed the access panel cover on the right wing, and went back to work on the wingtip. The sealant had cured nicely, and so I located and riveted in the W-412 tip rib. Location information is quite sparse, but you just put it where it fits.
After it was riveted in, I installed the wingtip. Alignment and clearances look good, but alas, I forgot to take a picture yet.
