"Today I worked on fitting the RH tank baffle to the spar, and adjusted my shims to fit better. I did not take any pictures of this, but I will try and get showing my spacers before it's all said and done.
Also, I cut the big hole on the fuel tank inboard rib for the access hole. I then drilled the access cover holes for the screws, and ultimately the rivet holes for the nutplates."
