Brief Description: Work on RH tank, and LH tank ribs
"Today I drilled the big hole for the tank access on the LH inboard rib, and drilled all the vent holes and vent line holes in the RH inboard ribs. I had my beautiful bride help me locate the ribs so I could drill the skin to them. I had clecoes in every other hole, so I let her drill the other holes. Until they got too high.... She's short. :)
So now, all the LH and RH tank ribs have all fuel transfer holes drilled, the access holes drilled, and the RH inner ribs have the vent holes drilled.
Next session will be to drill the fuel tank skin to the bottom of the ribs, and then to the spar."
