Brief Description: Deburred, primed, and prepped conduit holes
Not much time today. The holes I drilled for the wire conduit needed deburred, so I took care of that. I then touched up the holes with primer. I finished by installing all the snap bushings. NOTE: I decided to install the snap bushings AWAY from the rib flanges. This will make it easier when I rivet the main skin on, as I won't have to try to buck a rivet with the bushing in the way.
