Brief Description: Marked the top skin for drilling, drilled holes fo
Today I marked the top skin for drilling. I marked both sides of each rib, and main and rear spar. Also, I drilled the 1" holes for the conduit in the left wing. I temporarily installed the snap bushings, and checked alignment by temp installing the PEX pipe conduit. The template I used works GREAT! I then drilled about 300 holes in the top skin using a template that I made. No pre-punch here...
