Brief Description: Installed tie down, fabricated new angle
Today I installed the tie down for the right wing to the spar. It looks to be quite an anchor point! I had to fabricate a new angle for the nose rib forward of the aileron bellcrank rib. I finished my 2 hours by prepping and priming the four angles you see in image 3. Next time I hope to complete the permanent assembly of the wing skeleton, including the rear spar.
