Brief Description: Riveted nose rib angles on, located jigging holes.
Had a little time today to get out and rivet those last 4 nose rib angles on. Also, I used a #50 bit to drill the holes on the main spar web that will be used for leveling with plumb bob lines. I still need to drill the holes for the rear spar. I will then level the jig, and when the wing is square, temporarily bolt down the nose ribs to the spar, so I can fit the leading edge skin. Making progress...
