An easy hour today finishing up the LH aileron. Angie helped me install and remove clecoes. I riveted the bottom row of -4 rivets along the spar. These must be pull fasteners, as there is no access to the inside. I then squeezed the rivets on the end ribs and the nose ribs. I finished the aileron by installing the 406 and 407 attach brackets. The instructions recommend against installing these at this time, but the new powder coated 406 and 407 brackets were predrilled, as was the spar, so their location was already committed. (And I trust Van's holes are correct)
