Today I removed everything from the prime booth, and got everything ready for final assembly. Started with the top. Having to reach in from the back to buck those rivets on the top skin is not an easy task. You will very likely bleed. After all top skin rivets were set satisfactorily, I worked my way around, pulling the nose skin around and down. Getting all three layers to line up on the bottom is another fun task, but very doable. Ready to close up the bottom tomorrow.
