Brief Description: Completed skeleton assembly and primed everything
Today I did quite a bit. I got the nose ribs cleaned up, and straightened. I then drilled the ribs to the spar, and finished drilling the 408 reinforcement plated drilled to the spar. I drilled the counterweight to the nose ribs. and the main ribs to the spar. Disassembled everything, and prepared all pieces for prime. Finished the day by priming everything.
