Brief Description: Cable Mounting Bracket Fabrication Part 2
I Cut out the quadrant cable mount bracket and smoothed all the edges. Located and drilled the cable holes in the bracke using a step drill. I added cables back in and mocked up into position to see if proper angle was set with my cut before I drill the final mounting holes.
