Daves Web Site
Long-EZ
Ch9 Main Gear& Brake
2-3-2013
Gear Jigging Blocks
Using the plywood left over from the firewall, this step is just making 4 jigging blocks.
I did this very carefully and it was probably overkill yet all a part of trying to keep the build standard as high as I can.
The blocks fit two on each gear support as in the third pic. I had to open the holes just a touch so they would slide over the knerled tube.
Blocks match drilled
Trimmed per Plans
Jigging blocks on gear
Long-EZ Home
6788
Ch C HeadLight
Ch D Wheel Pants
Ch E Oxygen System
Ch10 Roncz Canard
Ch11 Elevators
Ch12 Canard Install
Ch13 Nose & NoseGear
112
935
Ch14 CS Spar
54
528
Ch16 Control System
Ch18 Canopy
Ch19 Wings & Alieron
122
1066
Ch20 Winglet/Rudder
68
510
Ch21 Wing Strakes
Ch22 Electrical
Ch24 Covers/Fairings
Ch25 Finishing
Ch3 Education
Ch4 Bulkheads
Ch5 Fuselage Sides
Ch6 Assembly
Ch7 Fuse Exterior
Ch8 Rollover/Belts
69
682
ChA Cabin Oil Heater
60
334
ChB Foot Rests
Engine Installation
Ferry Tank
MILESTONES
Pitch Trim
Roll Trim
Strange Tips
Tests
Wheel Pants
Wheel Pants
