Daves Web Site
Long-EZ
ChA Cabin Oil Heater
8-6-2017
no ref
Oil Heater 30 Bottom fitting
After ensuring the bottom slot was cut and clean I proceeded to flox and tape on the lower fitting as you see in Pic 2.
Pic 3 and this is my heat exchanger with Y valve at the top. This directs the warm air either forward, back or a mix of the positions.
Access slot cut
Glass and flox for the bottom
The basic unit revealed
Long-EZ Home
6788
Ch C HeadLight
Ch D Wheel Pants
Ch E Oxygen System
Ch10 Roncz Canard
Ch11 Elevators
Ch12 Canard Install
Ch13 Nose & NoseGear
112
935
Ch14 CS Spar
54
528
Ch16 Control System
Ch18 Canopy
Ch19 Wings & Alieron
122
1066
Ch20 Winglet/Rudder
68
510
Ch21 Wing Strakes
Ch22 Electrical
Ch24 Covers/Fairings
Ch25 Finishing
Ch3 Education
Ch4 Bulkheads
Ch5 Fuselage Sides
Ch6 Assembly
Ch7 Fuse Exterior
Ch8 Rollover/Belts
Ch9 Main Gear& Brake
69
682
60
334
ChB Foot Rests
Engine Installation
Ferry Tank
MILESTONES
Pitch Trim
Roll Trim
Strange Tips
Tests
Wheel Pants
Wheel Pants
