Daves Web Site
Date:  12-21-2016
Number of Hours:  20.00
Manual Reference:  No ref
Brief Description:  Wheel Pants from molds
Some years ago I bought a set of 5" wheel pants for my flying Long-EZ. Over time a very skilled fellow builder made a set of molds frrom these as you can see in pic 1. We did a set together intending to be an improvement on the bought ones, we made them a bit lighter. Well I never put them on my plane and then someone else needed them for his Long-EZ.
I ended up making another set from the molds recently. Using different materials. They are three ply, the inner and outer being S glass, a little lighter than the regular BID used on the plane and the middle ply is Innegra as I used on the underside of the nose.
It's a lot of work just to get this far. If you need a set better talk to the man with the molds, I'm done. The halves are roughly trimmed and the next step is to do some joins and see how we go.
Molds
Molds
Lots of work
Lots of work
Halves done
Halves done
