Daves Web Site
Date:  6-19-2016
Number of Hours:  10.00
Manual Reference:  No ref
Brief Description:  Wheel Pants from molds
Some time ago I bought a set of wheel pants for 5" tires for my flying plane. Michael, a VE builder, kindly made a set of molds from these. We then made a nice set of pants that were lighter than the original. I never put them on my plane and sold them off pretty cheaply, given all the work, to a fellow LE owner who needed a set.
I want lightweight yet very strong pants. I'm doing a three ply layup
1 Ply S Glass 288gsm 4HS
1 Ply Innegra 146gsm 4 Shaft Satin weave
So the Innegra is in the middle captured by the S glass. Innegra is a bit like kevlar except you can cut it easily. It is very strong and extemely tear resistant which showed in a test piece I did. I could not break it apart. The S glass failed with extreme bending but the middle section could not be failed without cutting.
So far as you see in pic 3 I have the 4 parts for one pant. I have to clean up the molds and make the second set. Weight so far is 2lbs 2ozs for the pieces, untrimed.
5" wheel pant molds
Note the weave
Note the weave
Four halves out of the molds
