Daves Web Site
Date:  5-3-2016
Number of Hours:  10.00
Manual Reference:  No ref
Brief Description:  Wright-Hanka Roll Trim Spring 1
While doing other jobs I thought I'd build the spring for the roll trim. I'm using the Wright-Hanka system that a few other canards have done with sucess. Mine will be an electric trim operated from a hat switch on the control stick. There will be a servo pulling and pushing the roll pushrod with one of these horse-shoe shaped springs inbetween.
I thought I'd try it in carbon fibre as I had a small amount of cloth. First up I found a bit of pipe and hot glued it to a board after taking out a bit on the bottom leaving a curve around 270 degrees. Then I covered everything in duct tape and added some clear tape around the base as you see in pic 1.
I did a six ply layup initally and peel plied it. Then I added some aluminium tube that I had drilled out to accept an AN3 size bolt. I did another 5 plys on one side about an inch long with a bit of flox for a transition. Once cured I did the other side using a mixing stick spacer and a couple of clamps and more peel ply. All this done as shown on Pic 2.
Pic 3 has my springs which look even nicer in person! I only needed one at 5/8" diameter. I've cut one down to .8" and have a thicker and thinner as spares. I made the initial mold wide enough to do a few as it was really the same amount of work as one. It feels great and nice and spingy. I'm pleased with this, the carbon is very pretty.
Duct taped mold
Duct taped mold
Layed up and tubes in place
A beautiful spring with spares
