Daves Web Site
Date:  5-25-2016
Number of Hours:  5.00
Manual Reference:  12-1
Brief Description:  Canard Alignment Pin mod 2
After the holes have been drilled out and the tubes fitted I needed to secure the nutplate for fixing. I also found that one tab was just slightly away from F22 so I added a ply of BID to its back.
Anyway I have the nice Garolite G10 and secured a couple of nut plates to pieces. You can see I countersunk the holes and made it all pretty. The surfaces were roughened for the flox too which went on after a thin coat of epoxy.
Rather than making a smaller backing plate and covering it with BID, I've gone for plates full size. The twisting forces will now transfer to the top surface of the canard so all I have to do is secure the plate to the tab and it will be ...super secure.
You can see the hardware in pic 1. Those AN3-55A are not cheap and it looks like a -54 would work better! I had to get a drilled one as undrilled were o/s and really ...its mainly in shear.
Pic 3 has the canard secured. Oh and did I meantion another 5 hours or so of sanding the canard profile. I don't even want to talk about it or log it. Looks like that is pretty much done too.
Pieces ready
Pieces ready
Floxed in place
Floxed in place
Canard secured
Canard secured
