Daves Web Site
Date:  9-16-2017
Number of Hours:  6.00
Manual Reference:  no ref
Brief Description:  Fuel System - Strake outlet pipe Part 2
The old hard point had to come out and it didn't want to. I won. Pic 1 shows where it was, you can see the peel ply yet to be removed. Now this area is well repaired with a couple of glue cycles and more of my precious fuel safe epoxy used. The new straight bulkhead fitting is in place. I have moved that hard point 2.5" to the rear. Thats what was needed.
Pic 2 shows where it is in relation to the feed pipe from the strake. I am using a straight fitting because I have discovered the 90 degree -6 speedflow fittings which are ideal here.
Pic 3 and you can see a nearly straight pipe going to the on/off valve. Its fits well and is more 'relaxed' than the other two attempts. The hose has a slight bend in it for strain relief although it is not under stress. Yes now I'm happy.
New moved hardpoint outlet
Side view
Side view
It works, I'm happy
It works, I'm happy
