Pic 1 shows the completed 'fuel samba line' cover I think we can call it. It is a curved bit of foam glassed inside and out and fits nicely into the other covers which partially hold it.
I spent some time on this and made brackets with nut plates and fitted all these things over several days. If you have read this far you would have seen lots of shots of that procedure.
Pic 2 is showing the curve I've worked out for the top. I completely forgot about where the canopy tubes go but I may have gotten away with it. We will see.
Pic three shows that I also completely forgot to put mouse holes in for the ferry tank straps so had to spend an extra couple of hours doing a cut out, glassing the area with flox corners and then a post cure clean up. Hey its all done now so it is in the past.
