Brief Description: Oil Heater 15 Oil Pump Mounting Part 1
Time to mount my heater oil pump. It took a while to work out a good place and a method.
Pic 1 has a piece of firewall plywood of which I have a full sheet. I've floxed in bolts matched to the pump in position of course and then added BID to secure the heads. Pic 3 is prep for what you will see in the next log.
