Daves Web Site
Date:  1-19-2017
Number of Hours:  10.00
Manual Reference:  IIL page 6
Brief Description:  Engine Mount 9
With the holes marked how in the world do I get perfect holes in an area that is very hard to jig??
Well I asked an engineer who has built a Rutan design. He said use the mark one eyeball with small drill sizes and edge up to the bigger ones with a bit of pull and shove to get things looking parallel.
WOT???!!! Well thats what I did. The beginnings of this are shown in pic 1 with getting smaller pilot holes in pretty good alignment. Then I mounted the mount, if you'll excuse the phrase, and got it all perfect again and used a serious number of clamps to keep it there. I slowly went through the drill sizes until I was close to my .025" for the AN4 bolts.
Now before we got here I found that I had a nice reamer for the job but it was marked 0.251" and my bolts micoed up at 0.248" So my trial holes gave a sloppy result. I asked the online experts what is the correct size reamer and got answers saying it wasn't critical and after all you measure with a micrometer and end up using an axe to cut things ...everyone's a comedian.
It took a couple of days but I ordered a 0.247" chucking reamer from a real engineering shop. It worked a treat and I have nice holes that need a slight tap with a plastic hammer to get the bolts in. I'm happy.
I do have some special washers planned that I've asked a machine shop to make for me. So for now I just put in some longish bolts with lots of washers as you see in pic 2. I'll show the washers in a later log when they arrive and you'll see what I'm on about. That said the mount is on.
Pilot holes
Pilot holes
Underside drilled out
Top side pretty
Top side pretty
