Many hours over several days went into all this and I'll save you the drama. These next logs are out of order too time wise. I was doing a few things simultaneously.
Pic one shows that I've got the hinges on which are countersunk screws and locknuts. The idea is to have everything removable in case I mess up.
You can also see I've floxed on some door stops that come to rest on the gear leg propping plate, as you can see in pic 2. I wanted these at the outer edges for stability and being more of the Garolite G10 I can just sand them down to make the final fit perfect. As it is they close nicely.
Pic 3 is the wheel up so you can see the fit. I still have plenty to do in the wheel well but we do have working doors now.
