Daves Web Site
Date:  8-22-2016
Number of Hours:  3.00
Manual Reference:  13-11
Brief Description:  Cutting the nose pieces
Time for the slightly nerve wracking job of cutting the canard cover piece out. This means two cuts with everything in line and I have to admit I took a while just laying out the lines and thinking about where things need to go. I've hot glued the hatches in place too. It keeps things stable.
I really did this over a couple of days as I wanted to put a lip on one cut line before the second cut. I've detailed that in the next log.
I've put a couple of pics in again just to show this easy cutting method. I hot glue rulers next to the lines and then use thin bladed hobby saws to do the cuts. I move the rulers and reglue as required and use the tip of the blade for curves just free hand.
It works out OK.
Straight cuts
Straight cuts
Cut lines
Cut lines
More straight cuts
More straight cuts
