Daves Web Site
Date:  12-26-2015
Number of Hours:  10.00
Manual Reference:  19-9
Brief Description:  Hinge Supports BID cover
Today was finshing off the sanding for this one ply of BID on the TE of the ailerons. This layup captures the counterweight and the hinge bases. I spent some time sanding and checking the surfaces. Only a very small amount of additional micro was required and I did that as part of the layup.
The pices are 66" long and the 45 degree comes out in one piece of the wide BID rolls I have. I did the layup on foil and a long board I'd used for earlier wing cover aileron area layups. It went pretty smoothly and I spent a long time ensuring no air bubbles with gloved fingers. Its quite a complex shape but seemed to go down OK. I did all the usual things, preping the surface with energy from sanding, pure epoxy first, good fibre/resin ratio on the foil piece and a little dry micro fill.
While just one long ply it lifted well and was easy to put in place. I lined up one side with predrawn lines and then once fitted, cut the other side for the 1" overlay. A little peel ply and a lot more finger work and I was done late in the evening.
Foil treatment
Foil treatment
BID down
BID down
No air visible
No air visible
