Daves Web Site
Date:  1-3-2015
Number of Hours:  5.00
Manual Reference:  Roncz C Sheet
Brief Description:  Canard Tip inboard ply
This is a simple little layup. Of course I spent ages carefully triming the tip to ensure elevator clearances would be OK. Its one thing to have a really small gap. I'm thinking I don't want it to jam in flight.
Once the gap was correct, time for a good clean out for the flox corner as in pic one. I filled the hinge pin hole with really stiff micro, did the usual slurry on the blue foam, pure epoxy on the glass bits and I made a template and cut out the one ply of BID with a 45 degree bias on foil. All the necessary steps despite such a small layup.
It all went well and I cleaned up the edges the following day as you see in pic 3.
Flox corner trough
Flox corner trough
One ply BID
One ply BID
Cleaned up
Cleaned up
