Daves Web Site
Date:  5-4-2014
Number of Hours:  10.00
Manual Reference:  13-10
Brief Description:  Headlight mounting 4
Yes this is all done over several days. While I was thinking and working on the wing core setup a nice diversion is the front light. I finally bit the bullet and made a cut in the front bulkhead to begin the fit.
Next was getting the light wired up to see what it really did and work out what combinations I needed. I made proper terminals and labeled things which means I can disconnect wires without drama. The 'diagram' with my Aveo Pegasus doesn't show internal wiring but is fine for adding switches.
I used the 5 offered functions as in pic two. You can see in pic 3 it is really bright with all the options set at max. After this and some online discussion I spent time learning how to wire an on-on-on switch to function as off-taxi-landing and got all the combinations down to 3 switches. I need to source a 3P3T however. All that remains is to learn how to draw circuit diagrams. So this simple light is my first project on that towards the 'wiring book' for the plane.
Made the cut
Made the cut
Wiring adventures
Wiring adventures
Yes its bright
Yes its bright
