Daves Web Site
Date:  12-28-2013
Number of Hours:  10.00
Manual Reference:  19-4
Brief Description:  Joining FC4 & FC5
Time to join FC4/5, the upper or LE of the wing.
Like most things these didn't really fit. I took the shear web area as critical and placed the two blocks on a straight edge. As you can see in pic 1 its not perfect.
A touch with the sanding block and I joined the pices in my gluing jig. A few pins are good for putting the edges in place.
Overall the foam is quite flexible before being skinned and I should be able to get it straight and sitting well when it comes time to join the wing together after the web and spar caps are done.
CnC cores not perfect
Join and clamp
Join and clamp
The busy workshop
The busy workshop
